Menus not working properly
mr_fatron
Post by mr_fatron »
Hi everyone,
I've been building an interactive DVD project with Ulead DVD Workshop 2, and recently have started having problems with the menus.
I'll drag to link menus to where they're supposed to go, and when I click the finish button to preview, it works fine, but if I burn the DVD, about half the links are wrong.
Something that's supposed to be linked to menu 20 will be linked to menu 3, and buttons that are checked as default highlight won't show up with the highlight.
I'm getting a feeling my project file is corrupted. Any ideas what's going on?
I did some searching and found someone else who had a similar problem. Click here
papcom
Post by papcom »
I had a similar problem. Then the support said I should upgrade to the most new version 2.231. After this my project worked fine.
mr_fatron
Post by mr_fatron »
I thought that might be my problem, so did update the system, but I'm still having the problem.
Is the project corrupt? Do I just need to start over now that I've updated?
SierraNomad
Post by SierraNomad »
That would be my approach.
rad
Post by rad »
I too as of today am having the same problem. I have a 60min dvd with only 3 menu options. Everything is linked correctly and when I preview it in workshop "FINISH" it works. But after buring 2 of the 3 linls do not work. Could it be the disc?? or am I just missing something.
I've done a project before with NO problem...something has changed. hmmmmmm
SierraNomad
Rad:
Have you tried the update mentioned by Papcom?
I'm just shooting from the hip and in the dark here, but you mentioned a previous project. Do you by chance have the files of both projects in the same folder? I know personally that that can cause ws2 to do some odd things.
Hope this helps.
rad
Post by rad »
SierraNomad wrote:Rad:
Hope this helps.
i will try the update. that is the only file i have right now. ido one at a time.
i've had no trouble in the recent past w/ ws2 just today this all started. i've changed media but i don't think that has anything to do with it.
thanks for replying.
mr_fatron
Post by mr_fatron »
For what it's worth, I recreated my project after I did the update and haven't had any problems yet.
The old project still doesn't work though.
praebo1557
Post by praebo1557 »
mr_fatron I completely gotta agree with you.
