dvd workshop running soooooo slow please help
nikkio3000
Post by nikkio3000 »
and the weirdness keeps going, now the program takes forever to open some video files, and then locks up when i try to open more then one at a time, also even when selecting the file to open it hangs on the selected file forever, i have been using the program wonderfully up till a few days ago , it was awesome and so fast now for some reason it is super slow and glitchy i have uninstalled it and reinstalled it twice, same problem i have more than enough ram and space, cause up until recently it just started this i also tried all the updates same thing happens, it's sooo frustrating anyone :cry: help please ? :(
It might be the clip you are trying to open and not DVDWS itself.
Try opening a different clip to see if the problem persists.
nikkio3000
hmmm that's weird :-/
that seems to be the case, one file will open in a snap and another will hang forever then finally open.........???? why???? They were origianlly avi files and i converted them to vob files then renamed to mpg........... i used the program avi2dvd to convert them. is it the files itself ??? what wrong with it?? thanx for replaying :D
Yes it will be the files themselves. I have had this happen a few times in the past. The corrupt MPEG can come about for hundreds of different reasons.
nikkio3000
corrupt mepeg?
oooooo so that's the problem, hmmmm, maybe trying a different coinverter would help? any suggestions :?:
DVDDoug
Moderator
Post by DVDDoug »
:shock: Oh No!!!! :shock: Do you still have the original AVI files? Do you know you can feed the AVI files directly to Workshop? It will convert them.
(I'm assuming "regular" AVI/DV files, like from a digital camcorder..... An AVI can actually contain all kinds of weird formats... DV, MPEG-2, DivX/MPEG-4, etc.) If you're not sure, AVI/VD takes-up about 13GB per hour of disk space. If it's less than half of that, it's something else....
A VOB is a special kind of MPEG. I don't know the technical differences, but changing the filename to MPG apparently works about half of the time. I know you're NOT using a VOB from a commercial DVD, but for example, I'm pretty sure you'll have problems if you change the file name of a VOB with subtitles, multiple soundtracks, multiple angles, etc. (That's ignoring the encryption issues.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
nikkio3000
hmmmmmmmmmmmmmm...........
no these are not from a dvd or anything like that just downloaded avi files with the subs already encoded in not on a separate file and no angles etc. nothing special.................... is there a way you can tell if it is encoded a certain way, i may just have to let dvd sorksop do the encoding for this dvd :( takes forever , is there a way to spped up dvd workshops encoding??
Downloaded "AVI" files are normally either Xvid, Divx or MPEG4 files which are all more or less the same, a very highly compressed format - more so than MPEG2, but retaining a very high quality of playback.
Do a Google search for "convert Divx" and you will find plenty of programs about. One good and free program is SUPER
