Capturing Video
cgflembo
- motherboard: Acer Inc Chapala
- processor: Intel core 2 duo cpu
- ram: 2gig
- Video Card: NVIDIA GeForce 8600M
- sound_card: Realtek High Def Audio
- Hard_Drive_Capacity: 115gig
Capturing Video
I dont know if this is a silly question but is there a way to stop the juddering like strobe effect when viewing the screen on the pc while capturing the video from my camcorder. I am using VideoStudio 9.
cgflembo
THoff
Depending on exactly what form the distortion takes, it could also be indicative of other problems. If you are capturing DV and don't have a relatively powerful computer, then you may be capturing using DV Type 2 encoder and your computer cannot handle the output. The capture may show juddering video and corrupted audio. In that case, change to Type 1 in the Options cogwheel icon on the capture screen.
If you are capturing direct to mpeg-2 format, then you may be capturing using the wrong Field Order. If capturing from most digital sources, you should normally be using Lower Field First (Field Order A); while most analogue devices, including most capture cards, use Upper Field First (Field Order B).
We normally recommend against capturing direct to mpeg-2 unless you have no alternative (e.g. from a capture card which does not allow capture to DV/AVI format), and particularly if your computer is not a powerful one.
