joining mpeg1s and mpeg2s without re-encoding
uleadme
Post by uleadme »
I have quite a few mpeg 1 files, and mpeg 2 files which I would like to join into larger files (no larger than 2gb though). Note, I don't want to join mpeg 1 to mpeg2, just mpeg1 to mpeg1 and mpeg2 to mpeg2.
My question is does VS9 do this without re-encoding? If so, how should I save the joined files? As "same as project settings" or "same as first video clip"? I realise that if I edit them, it will re-encode at the cut points, but if I don't edit them, my feeling is, they should stay in their original form without any loss of quality. Am I correct?
If VS9 can join without re-encoding, then I won't have to go out an buy specialised mpeg joiner, though I guess if I want to edit them then I might have to invest in womble or videoredo or the like.
thanks
GeorgeW
Post by GeorgeW »
Were the videos made using the same properties? Like all the mpeg1's have the same properties, and all the mpeg2's have the same properties?
What happens if you just try a quick test -- put them in a project and output with smart render :?:
If you have to do edits, then the two apps you mentioned have a good reputation (I've never used them though).
George
uleadme
Post by uleadme »
Yes, all the mpeg1 files I want to join have the same properties, and so do the mpeg 2 files I want to join. In this case, if I just join files having the same properties, will VS9 doing any re-encoding, and thus (further) diminish video quality. I know womble and videoredo can join without re-encoding, but can VS9?
GeorgeW
Post by GeorgeW »
What happened when you tried it :?: :?: :?:
George
uleadme
Post by uleadme »
It seems to work fine for both mpeg 1 and mpeg 2. That is, they seem to join without much or any degradation of quality. Also the creation of the file, in "same as project properties" is pretty quick, all of which leads me to think that there is either no, or very little re-encoding. Am I correct, or am I missing something?
GeorgeW
Post by GeorgeW »
I don't think you are missing anything :)
Just watch for "audio drift" in long video combinations -- not that you will have any, just something to keep in mind (I think that's where those programs you mentioned really shine -- ability to slice/dice mpegs and maintain audio/video sync).
btw, if you don't do any edits, you might be able to just Author a DVD with the different files (depends on how long they are, and if you don't mind a little "pause" between titles on the DVD -- fade to/from black usually masks the "pause" between Titles on a DVD during playback).
George
