Video 7 SE DVD error message Clip too long
SKI
I am trying to edit an MPEG 2 file that is 1.9gb in size and consists of 87,811 frames when dragging the selected clips to the Timeline I get the following message: 'The duration of the inserted effect clip is too long. I will be trimmed to fit'. I wouldn't have thought that the file in question was particularly large. Is there a 'work around'?
Hi Ski
This is bad wording on Video Studio’s part.
In preferences if you have ‘use default transition effects’ selected,
When you insert a clip that is shorter in duration than the transition effect you receive the warning.
Video Studio then reduces the transition effect time to match.
Hope this Helps
Trevor
Hope this Helps
Trevor
