pasting text into the title track after copying
brucefl
motherboard: I7 3770
processor: 3-4 Gig
ram: 12gb
Video Card: NT Geoforce 640
Hard_Drive_Capacity: 2 T
Corel programs: VS21 VS18thru21 and more PIX13
Post by brucefl »
Is there a way to insert text into the title track?
I have some information that I have copied and tried
to paste into the title track, and have not had any luck.
Even if the text box is active. Is there a way to do this?
thanks
THoff
Post by THoff »
I've done it, but I don't recall if I used Ctrl-V or Shift-Insert (two common Windows shortcuts) for this.
bop
Post by bop »
As far as i can remember the only place you can paste onto is in the library on the right side of the preveiw screen then drag to the title track
Hope this helps
Brian
Video Studio X-3
LG BH10LS30
LG GH22NS50
Post by BrianCee »
NO - you cannot paste text into the title track - you must paste (Using Ctrl+V) into the preview window - the text will then appear in the title track at the position of the cursor.
Just click on the 'Title' tab at the top of the screen - then double click in the preview window as instructed - the use Ctrl+V to paste any text .
THoff
Post by THoff »
To clarify, no, you cannot paste text directly into the tiack, you need to create a title first, and while editing it, you can indeed paste text into it.
