videostudio 7 not reconising NTFS system
m rixon
Post by m rixon »
I have just installed videostudio 7 on a new computer and the prog. does not recognise the fact that my hard drives are NTFS subsequently all capture is split into 4GB files.Is this posibly because the drives are connected on SATA rather than IDE cables.Is it possible to force the prog. to recognise the NTFS system.
Post by Trevor Andrew »
Have you installed the VS 7 patch
Try this link for download info:- http://www.ulead.com/tech/phasedout.htm
Quote
VideoStudio 7 Update Patch (Build Number: 7.01, Released Date: 2003/04/29)
Major
1. Sony MICROMV Capture - Fix video/audio synchronization problem and preview quality when capturing video files from MICROMV.
2. Video File Conversion - Fix the problem when convert video files from NTSC to PAL or PAL to NTSC.
3. Audio Mixing - Fix the output quality problem when doing audio mixing.
4. Split by Scene - Fix the crash problem when using "Split by Scene" in Edit step and there's no D drive or the D drive is CD-Rom.
5. Seamless DV Capture - In the patch, there won't be file size limitation when capturing video on NTFS system.
Unquote
Hope this helps
Trevor
m rixon
Post by m rixon »
Trevor Andrew.Have already installed patch but have just reinstalled it again just in case that was the problem .Will report back.
m rixon
Post by m rixon »
Problem solved.Reinstalling the patch seems to have worked.Just captured 18.5 GB file'Thanks very much for your help. :D
Glad to hear you got it working.
All the Best
Trevor
