Thanks for the replies...Maddrummer3301 and Videoman. In response to your questions..Yes I did save the project and there after I have the problem. I did try opening the same file in a totally new project. Same problem. I even imported A copy of the original "problem file" from my laptop in A new project with a different file name...same problem.
I made about 25 files all the same way and only this one has the problem.
I shot the MPEGS with my Sony camera (digital still camera in movie mode) I then saved them on my hard drive. Then I import them into MF4.
I have no other Video editing apps...
I am a newbie to DVD authoring...I don't know how to tell If they are DVD compliant.
When I Import the file into a new project, A message box comes up and asks "the file Reel#8 has been modified, do you want to relink It to another file?" I chose yes and It takes me to the location where the file originally came from, an then I choose the same file...Reel#8. It still has the same problem.
The properties of this file are MPEG 1 , 347,147K , duration 149.040 seconds. (This file originally is about 16 minutes long.)
Video properties MPEG-1 Video, 3726 frames, 24 bits 640 by 480
frame rate 25.000 frames per second, Variable bit rate.
MPEG Audio layer 2 files, 4,769,280 Samples. Layer 2. Bit Rate 64 kbps.
I even uninstalled the program, manually removed the remaining files, restarted the computer, reinstalled the program, did the update pack, and I still have the problem.
Could you explain "DVD compliant" and relinking?
Thanks in advance for the help .
Calibrator
