I want to use the "FX: Fade" transition affect but it goes too slow.
I've noticed in the folder structure there is a "fade.dll" which I'm guessing controls the fade. I'm wondering if somehow this could be edited to do a 1 second fade in stead of a 2 second? (i'm guessing the current fade takes ~2 seconds)
Does anyone know how to make the fade go like twice as fast? I'm also wondering if this could be an addition affect in MF5?
Thanks, Nick
DVD Movie Factory 4.0 Transition Effects Question/Problem
leenicho
alright
So it's not quite file:prefs in MF4, but it's the icon in the lower left and then preferences.vidoman wrote:Hi Nick,
To change the transition effect time, go to File>Preferences. There you can set the durations for Transitions, Image Display, etc..
I get Slideshow effect duration [3]
transition effect duration [3]
audio fade-in/out duration [3]
So, just to test I got in and add 113 images = 339 w/out transition
I then add transition and it goes to 563 (563-339=224)
I then delete the slideshow, change it to 3,1,1 so it should be 1/3 the time
but I get the same timings, 563. Perhaps somehow it's not saving? If I go ahead and put like 3,12,12 it stays at the same too, somehow it's not "saving"
So, I try and time it and it does seem to take 1 second to fully transition, I guess really I want it to take .5 seconds, which seemingly isn't going to be possible, so perhaps I will have to use no transitions.
Thanks for the help though, unless you have some other ideas..
When you use transitions, the duration of the transition is borrowed from the neighboring image clips. For an example if your image duration is 5 seconds (to make the math a little easier), and the transition duration is 2 seconds.
Then for 10 images without transitions the total time would be 10 * 5 = 50 seconds.
Now we add a transition:
So for our 10 images the total time would be: 10 images * 5 seconds, subtract 1 seconds from each image (10 seconds) = 40 seconds...
So when you add a transition effect, you don't add additional time, because it is an action applied to the clips, and uses the clips time.
Hope that helps...
Hope that helps...
I am having the same problem
I am using DVD MovieFactory 6
I have changed the slide show duration from 5 to 7 to 12, and I still get the 3 second slide show. How do I fix this.
Additionally, is there a way to add slide show transition to all slides at once?
Thanks!
Thanks!
