Ulead VideoStudio 9 The memory could not be "read"
helium
Post by helium »
I tried Burn to disc, Create DVD folders, Create disc image file, it always give me the following error. Please help.
The instruction at "0x76f6122f" referenced memory at "0x00000008". The memory could not be "read".
tyamada
Post by tyamada »
Here is a quote from VS9 FAQ page.
"I get this error message, "MEMORY COULD NOT BE READ.?What do I do?
* Increase your virtual memory. Go to My Computer > Properties > Advanced > Performance > Settings . In the Advanced tab, click Change and set the virtual memory as the values shown below:
Custom Initial Size: 1024
Maximum Size: 4096
Click Set then OK . Restart your computer."
helium
Re: Ulead VideoStudio 9 The memory could not be "read&
Post by helium »
The computer has 2GBs physical memory, the virtual memory has already configured to Custom Initial Size: 4096, Maximum Size: 4096. The CPU is Pentium 4 3.4 GHz.
Helium
jchunter
Post by jchunter »
Helium,
Are you following the Recommended Procedure in the top sticky post?
What are your video properties?
helium
Post by helium »
I did try to create the video file first from my project recommended from the sticky post, it is working alright; but the result is not what I want since it cannot create the chapters.
I will try to Burn to disc, Create DVD folders, Create disc image file with recommendated configuration from the sticky post. I will see the result on Monday.
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Lower Field First for digital capture {if capturing analog use "Upper Field First"}
(DVD-NTSC), 4:3 (or 16:9 for widescreen)
Audio data rate: 224 kbps
You said "...but the result is not what I want since it cannot create the chapters". I am not sure what you mean by this. The chapters are only created in the authoring stage of production, when you create the menu. At the same time you can elect to create chapters or not. When were you trying to create chapters, and how were you going about it?
helium
Post by helium »
Ken,
My error message is happened when I did the Burn to disc, Create DVD folders, Create disc image file. At that stage, I have created the chapters.
Regards.
