uLead Autodector starts up 'disabled'
JRago
Post by JRago »
I just installed uLead MovieFactory 3.5 Suite Deluxe.
The uLead AutoDetector starts up when I log into WinXP but it starts up 'disabled'.
I can 'right click' on it and 'enable' it.
Shouldn't it start up 'enabled'?
If so, how do I fix it so that it starts up 'enabled'?
JRago
Personaly I have deleted it from my Start Menu and prefer to do things my way. If you want to use it you should find it located at
Start | All Programs | Startup
Just right click the icon and adjust the properties to your liking.
JRago
Post by JRago »
It's NOT launched from my start folder.
It appears to be a service.
When I login to WinXP it starts up and resides in the system tray.
It starts up in the 'disabled' state.
I can 'right click' on it in the system tray and 'click' on 'enable'.
As I said I deleted mine.
See if its in the Windows Registry at the following location:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
JRago
Post by JRago »
Yes, that's where it starts from.
What I need to know is how to change it from 'disabled' to 'enabled' WHEN IT STARTS.
Please view this post it may help
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=6883
JRago
Post by JRago »
No, that post was of no help at all.
It does NOT address my question.
My situation is:
uLead Autodetector starts automatically when I login to WindowsXP.
It shows up in the system tray.
The problem is that it starts up in the "DISABLED" mode and has to be "ENABLED" manually from the properties menu you get when the system tray icon is right clicked on.
My question is:
How do I change the behavior of the Autodector program so it starts up in the "ENABLED" mode?
Didn't the post by 2Log in the above link help?
right click on the Ulead Autodetector icon on the system tray then select Options.
htchien
operating_system: Mac
Post by htchien »
When Ulead AutoDetector starts up, is there a red mark on its icon? If so, then it's disabled; otherwise it's enabled.
The Disable Ulead AutoDetector item in the menu is not a status but a command. It means Ulead AutoDetector is already in enable mode and you can use the command to disable it.
Hope this helps.
H.T.
Ted (H.T.)
maddrummer3301
Post by maddrummer3301 »
RIGHT-CLICK on the icon that is on the task-bar that your complaining about and make your choices.
You select "Enable" if it's disable and disable if it's enabled.
To remove it from memory choose "Options" -> "Close".
To stop it from loading on startup:
Right-Click and choose "Options" then
In the next screen on the BOTTOM LEFT SIDE "UnCheck" the box that says
"Run AutoDetector when Windows Starts up".
That was in the post that Steve linked you to. I think you missed all the options that appear when you right-click on the icon.
MD
