Problem: Can't build capture Graph using VS9
vrocrider
Post by vrocrider »
I have a Sony DCR-IP5 NTSC Digital Camcorder. I can control the camcorder, but I'm unable to capture the video to my PC. The capture device is MICROMV and the format is MPEG. :?:
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
no capture
Post by Ken Veal »
More info needed about your connections and what exactly what proceedures you are following and the settings used
rickety
Post by rickety »
I too have the same problem. I have followed the recommended setup, though I cannot find the MPEG Settings dialog box to check that!
The message "Failure to create a capture graph" comes up. The camera is detected and can be operated by the play, stop, rewind etc.
I am unable to evaluate the trial version and Ulead customer service have not replied (except to say they have my message). Any help greatly appreciated.
Ken Veal
ram: 32 GB
mpeg settings
Post by Ken Veal »
Select MPEG from the format drop down arrow list in the CAPTURE SETTINGS tab,click options,select VIDEO & AUDIO CAPTURE PROPERTY
SETTINGS,click ADVANCED and then edit as required in the MPEG SETTINGS dialogue box
Re: Problem: Can't build capture Graph using VS9
vrocrider wrote:I have a Sony DCR-IP5 NTSC Digital Camcorder. I can control the camcorder, but I'm unable to capture the video to my PC. The capture device is MICROMV and the format is MPEG. :?:
You appear to be capturing to the wrong format. try to capture to DV/AVI
instead of MPEG
rickety
Post by rickety »
Thanks for the suggestion Steve. When I tried to select either DV or AVI, it deselects MicroMV as my capture device.
I noticed that I did not clearly state that the camera is MicroMV, and I don't expect everyone knows all the Sony models! This one is MicroMV and from the history of posts there do seem to be some problems with this clever, (too clever for Sony even) format.
rickety
Post by rickety »
fwiw, I downloaded MediaStudio 8 trial and the capture program with that suite was able to handle my MicroMV camera.
Unfortunately the installation did not "fix" the VideoStudio 9 install, but I suspect that was a bit too hopeful.
Does anyone who understands the meaning of the error message, have any ideas what VS could be lacking that is set up properly for MS?
I've only got about 4 days of the VS trial left, then I'll retry when VS10 comes out in case that download fixes it.
Rick
