Hello,
When i try to get edit my theme and add my music to the slideshow and transitions etc etc.
When i press the browse button i only see one of my pictures, but i have over a hundred pictures in the slideshow.
Also when i play the slideshow it just loops the one picture.
HELP!
thanks
Tanya
Theme Setting Issue
- michaeltee
- motherboard: HP 82F1
- processor: Intel Core I5 7400 3 GHz
- ram: 16 GB DC
- Video Card: Intel HD Graphics 630
- Hard_Drive_Capacity: 2TB Hybrid
- Monitor/Display Make & Model: Samsung S24D300
- Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Your "browse" button is working correctly. Clicking "browse" displays a single thumbnail image representing each slideshow you have created. So, one slideshow = one thumbnail image; 2 sildeshows = 2 thumbnail images, and so on. If you have created only one slideshow you do not need to use the "browse" button because the single thumbnail you're seeing represents the entire show. If you have more than one show, click "browse" and then click the image of the show you wish to edit. Once the desired show is selected, you may apply whatever effects you want from the panel to the right of the preview screen. The effects you select here will apply to the entire selected slideshow.
If you are seeing only one image when you attempt to preview your show, go back to the "organize" tab and click the thumbnail (to the far left) that represents the correct show. All of the images you have added to the show should appear on the right side of the UI. If necessary, use the scroll bar to verify that ALL of your images are shown. If so, you should be able to preview the entire show by clicking the "play" button from the "2 Theme" tab.
Does that help?
-Mike
Does that help?
-Mike
