MF5 appears to be using different encoder settings. Continued.
snoops,
I just discovered that myself.
Whatever you set the bitrate at under the compression settings ends up being the Max_Bit_Rate and the Average_Bit_Rate is much lower than that setting.
If you manually set the bitrate while in the "Advanced Screen" and return
back to the compression tab one can see the bit rate is Higher than what you set in the advanced tab.
Actually, the encoding is similar to the Sony Dvd Recorder I have.
This thread is way off topic so I'm starting a new thread with this posting.
Answer to the new thread ok because this ones alittle of the topic of the original post.
I'm burning a dvd with the different encoder settings now to a dvd-rw to see how the video looks.
MD
MF5 Encoder Settings (Cont)
maddrummer3301
