Graduate an image tpo black
TSG
Post by TSG »
If I have an image, how can I start to fade it away, about 50% across the screen, to solid black by the time it reaches the edge?
keenart
Post by keenart »
On the Comman Menu/Fade-out or Ctrl plus H
For an active object or a selection, this command opens the Fade-out dialog box to make colors to disappear gradually.
It is a little tricky to use, but works well. You might try another image as practice before trying the effect on your good image.
TSG
Post by TSG »
It is tricky isn't it! But I think I've got it now, thanks very much!
heinz-oz
Post by heinz-oz »
Best practice, after opening your image, is to duplicate your image (Ctrl+D) before editing. That way, you always have the original to fall back on :wink:
TSG
Post by TSG »
What I do is duplicate the layer and work on that.
heinz-oz
Post by heinz-oz »
And if your system crashes while you are at it, you might find your image later with all layers merged. :wink:
TSG
Post by TSG »
Will PI do that? That's a bit scary!
I must admit I'm used to Adobe PhotoShop CS, but I can't afford it personally so I use Elements and now PhotoImpact 11 as well, at home. But Photoshop is incredibly stable and never crashed on me.
PI11 hasn't crashed so far, but when it does, I hope it doesn't save a merged copy of my image!
I use layers so I can use the transparency effect, at a later date, to tune the effect of, in the case, a fade to black.
And I always have the original image I'm working on to compare/contrast, just by turning off the adjusted layer.
heinz-oz
Post by heinz-oz »
TSG wrote:Will PI do that? That's a bit scary!
I immediately gathered that when you talked about layers :wink: PI has objects, same thing, different name. I do know off people who had all objects (layers) merged when they recovered an image after a crash. One of the reasons why I use my approach :wink:.
I also save with alternating names after I make major changes. Never lost a minute of work jet to crashes but one never knows :?
TSG
Post by TSG »
Yes, funny that my "Layer manager" manages "Objects" :)
Many thanks for the advice. I shall keep saving my work!
