Retriving projects
SUBARUNORWAY1
Retriving projects
is it possible if the project was not manualy saved it says in the general setup that it automaticly saves every 10 min, it got stuck when i was playing the project so had to restart the computer, it realy suck if i have lost two hours of work
heinz-oz
You didn't say which version but, AFAIK, the autosave will only kick in if you saved the project once yourself.
Check in the default location for your saved files if there are any that you don't recognize. I don't use the auto save function at all, rather manually save frequently with alternating names. The project files are rather small and take not a lot of disk space. Having alternating names allows me to go back to a previous stage if something I did went wrong.
SUBARUNORWAY1
