Some wrong happens to my pc
natifa
I'm a newbie.
Nature of the problem:
I looked up the CPU Usage and PF usage in Task Manager while using Video Studio 8. I observed that after some time (some 1 to 5 minutes) that I use Video Studio 8 for editing, I notice that my PF usage bar goes up gradually. Then suddenly after another couple of minutes the computer says:
"Insufficient memory"
After that, I wont be able to use the program. The computer becomes slow and sometimes I cant open the other programs in my computer. I'm wondering if my Video Studio 8 has a bug or.. my computer needs more free space.
System information
Not sure if this is what you're asking for but here:
Intel (R)
Pentium (R) 4 CPU 2.66GHz
2.66 GHz. 1.00 GB of RAM
My Drive C has free space of 3.85 GB out of 74.5 GB
System information
Intel (R)
THoff
If it's the original, unpatched version of UVS 8, then yes, there is a known problem with a memory leak. You can download a fix for that here:
http://www.ulead.com/tech/vs/vs_ftp80.htm
The patch to V8.01 will take care of the memory leak.
100% CPU utilization during many Videostudio operations is quite normal, video editing it is very processor-intensive.
natifa
natifa
maddrummer3301
There was a setting under "Preferences" that affected the memory and swap file usage which was corrected in an update.
It was pointed out by J_Warner I believe.
I can't remember the setting so you may need to experiment with that.
If you don't need it set the "Undo" setting to 3 or less, instant playback and playback on preview screen only.
I know that having "perform non-square pixel rendering" checked either on or off (I think it was off). Caused large physical memory usage which then windows would starting paging. I think that was the real bug.
Hope this helps,
MD
Hope this helps,
MD
natifa
Umm.. I was able to download and install
VideoStudio 8 Update Pack
For Retail and ESD only
I downloaded
VideoStudio 8 SE Update Pack
For OEM bundle SE versions only
and
VideoStudio 8 Daylight Savings Time Patch
but I cant seem to install them. It says:
Installer cannot find Ulead Video 8 Patch on your machine. Please install Ulead Video Studio Patch first.
I'm not really sure how to do this.
I downloaded
and
- ram: 2 GB
- sound_card: Intel GMA 950
They are different versions. You obviously have the full version as you state you have it on CD.natifa wrote:Umm.. I was able to download and install
I downloaded
and
The "SE" version is a restricted version normally given away "free" with some hardware such as a camcorder or TV card etc.
The OEM version is another restricted version that comes "Free" with a new computer.
