after I edit my movie, I go to SHARE and click the create video file and chooses mpeg. and the problem is after I burn it into cd, my vcd player can't play it. I just want it into a vcd.
please help me.
creating into vcd
I read your post as though you are just burning the MPEG file to a CD and expecting it to work - I may be wrong - if I am - Sorry - but if I'm right you cant do it just like that.
After creating the video file you then need to go to "share" (again) but this time choose "Create Disc" and from the new screen which opens choose VCD as your format and proceed from there.
If you are doing that and it will not play on your DVD player then check the specification of your player, not all DVD players play VCDs. If it should play VCDs but not yours then post the spec of the files on the VCD on here and we'll have a look at those.
THoff
Some DVD players can play raw MPEG files, but the vast majority cannot, and you need to author a VCD as Brian pointed out. You can check to see if your DVD player supports VCD by searching the VideoHelp DVD Player Database.
