Why does it play on mine and not his??
Ericl
Post by Ericl »
HI
I use VS9.
I just made a DVD for a client out of a VHS tape.
It plays fine on my Home DVD player but it doesn't on his DVD player
He says there's no sound.
Another client had a same thing some times ago.
The DVD would not play at all.
Is it something to do with the model of DVD player?
Or else?
If needed, i will give all informations concerning my system and configuration.
I just thought it would'nt be useful at this point
THANKS
Post by BrianCee »
Yes it's a sad fact of life that not all DVD players play all DVDs - especially ones burned on a computer as opposed to commercially pressed ones.
It is very much down to the specifications of the users DVD player - some will only play DVD-R some will only play DVD+R etc. - you need to check out the full spec of their players to see what would work for them.
If it's any help the consensus seems to be - the cheaper the DVD player the more likely it is to play *most* burned DVDs
Ericl
Post by Ericl »
Thanks Brian for this quick reply
DVDDoug
Moderator
Post by DVDDoug »
It seems that your client's player can play the "burned" DVD, but you may have used a non-standard audio format.
The DVD standard supports 3 different audio formats. The correct one depends on where you live:
NTSC (North America, etc.) All NTSC players must play LPCM & AC3 audio. Everything else is optional.
PAL (Europe, etc.) All PAL players must play LPCM and MPEG-2 audio. AC3 was optional in the past and new PAL players are required to play it.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
tyamada
Post by tyamada »
Here is a link to a DVD compatability chart, you might want to use it when creating DVDs for friends.
http://www.videohelp.com/dvdplayers
Doverwhite
Post by Doverwhite »
According to threads on another forum the most multi player compatable recordable DVD's are DVD+R's bitset to bookmark as DVD-ROM a process which I and apparently others do not understand. ( i.e. the recording is made to "look like" a commercial DVD). Several DVD burners these days are apparently set to do this automatically when burning a DVD+R (E.G. BenQ and my own Phlips DVD8701 supplied with my Dell PC)
Using DVD Identifier I can confirm that Bookmarking to DVD-ROM only occurs when burning a DVD+R. I have been carrying round a couple of +R DVD's burnt on my PC and have tried them on several friends DVD players and two DVD -recorders and DVD players in their PC's as yet without failure. Whereas a DVD-R fell over on about 25% and a DVD+RW played on only a few.
This whole story confuses me as I always thought that DVD-R being a DVD Forum standard was the closest to their DVD-ROM standard but....?
The problem with the chart linked by tyamada does not include the cheapo brands of player sold at supermarkets in the UK (Akura, Bush, Cello, etc.......)
THoff
Post by THoff »
To add to what DVDDoug wrote, I have a big problem with Ulead deciding to use MPEG2 audio for some of the NTSC DVD video templates.
They are doing their customers and themselves a huge disservice by choosing to create video files that are not guaranteed to be compatible with otherwise fully compliant NTSC DVD players.
If a user is aware of the ramifications of using MPEG2 audio for NTSC disks and wants to edit the templates, that's fine, he/she can do so. But to ship the templates like that is a really bad decision.
