Typeface Square 721BT not found ?
Hello, i capture video with uleadvideostudio 9 than i authoring with moviefactory 4, when i import file moviefactory say
Error Report:
Typeface Square 721BT not found.
What does it mean? The file is correct import....
Thanks at all....
Error Report:
Thanks at all....
htchien
I believe Square 721BT is a name of font in Windows. When the program cannot find a font in your system, it will show a warning message and try to use the default font in Windows so your project can be imported.
Make sure the font is installed in your system. If the font is already installed but the program still show the warning. Try the update packs of DMF4 in http://www.ulead.com/tech/dmf/dmf.htm
If this does not help, report to Ulead via tech support.
Ulead Tech Support:
http://www.ulead.com/tech/techsupport.htm
Hope this helps.
H.T.
Ulead Tech Support:
Hope this helps.
H.T.
Ted (H.T.)
- ram: 2 GB
- sound_card: Intel GMA 950
You can add some free fonts to your system here:
http://www.ulead.com/download/freefonts/download.htm
Steve J
Steve J
jcc
Usually, this kind of thing happens whan you move a file from one system to another, and the new system doesn't have the same fonts installed. Then, Windows trys to substitute a font that it "thinks" is similar.
I did find Square 721BT On the Net! You can download and install it.
EDIT-
Ummmm.... Maybe there's a trick to downloading it... I couldn't figure it out.... I think jcc is right. It's not free from that site.
EDIT-
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
jcc
- ram: 2 GB
Check to make sure you haven't already got it.
Download this free font viewer to list all your fonts http://www.horizon5.co.uk/FontView.exe
Its listed as being on my machine but I can't see it in the Windows Fonts Directory and have also done a search. It must be masquerading under some other name.
Steve J
Steve J
- ram: 2 GB
Cancel the above, I've found it and yes it was masquerading under another name!
I've put a copy here (I haven't bought any so wherever it came from its free.)
http://www.steve-jones.pwp.blueyonder.c ... 0246M_.TTF
Regards
Steve J
Regards
Steve J
jcc
