Centering a image by dragging
Bobed2121
I know that in Photoshop if you select a image and drag it into another if you hold down the shift key whilr dragging it will center. Can this be done in PI11?
keenart
Ulead does it different.
Drag your image into another, and while highlighted right click the mouse, and on the Menu Item list, select Align, then Center Both.
To cut and paste, from the menu select Paste under Pointer. The image will paste to the center of the other image. The hard part is trying not to move the mouse while you click the left mouse button to deselect the image.
Therefore, I use the other method.
