Slide show; different transitions between each image
sjacobso
Post by sjacobso »
I’m wanting to know how to setup a slide show so that between image1 and image2 and have transition A, between image3 and image4 I have transition B etc.....
I’m hoping there is a way to select different transitions between each image. Right now, the last one selected becomes the default for the entire show.[/b]
Jodi Frye
Post by Jodi Frye »
which version of pe are you using ? I have 8.5 and there is an option for 'random' effects which puts random transitions between photos...or, click on photos one at a time and choose which effect i want.
sjacobso
Transistion Selections not working as you've described
Post by sjacobso »
I'm also running 8.5, and I've done just what you've mentioned. Select a slide, go to transistions, select one, go to the next and next etc... However, as I mentioned in my first post, the last transistion selected becomes the default transition for all.
Jodi Frye wrote:which version of pe are you using ? I have 8.5 and there is an option for 'random' effects which puts random transitions between photos...or, click on photos one at a time and choose which effect i want.
