Hi Dave,
So do you have MM Flash (whatever version)? I know there has been alot of issues with VS and recent Flash movies. I thought at one time it was due to Flashplayer 8, however that doesn't seem to be the case.
When you install VS9, it installs a version (unknown, but I think they are using version 7.00?). What may have happened is that your install ( I know that's the last thing you want to hear right now), is faulty. When you reinstalled, did you first do a complete, clean, get rid of anything that resembles, looks, acts, could be related to, or might have tried to pose as, Video Studio 9? The instructions for that are located in a VS thread. Just do a search for uninstall, and you should find it.
I was going to run it down for you, but instead I just copied and pasted it, (I know call me lazy for not wanting to search for it) from Notepad, where I copied to, so I would have it. I have found that when I come across good tips, and info here I copy them to a notepad file. Just a short time reading here, it told me I will be needing this in the future so why go hunting later....
1) Clean up C:\Windows\temp directory. Clean up all files in C:\Documents and
Settings\[UserName]\Local Settings\Temp folder. Uninstall VideoStudio 9 from
control panel Add/Remove programs.
Delete following folders
=>C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead
VideoStudio
=>C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc
=>C:\Documents and Settings\[Username]\My Documents\Ulead VideoStudio
=>C:\Program Files\Common Files\Ulead Systems\
Proceed to step 2, even if you can't complete step 1.
2) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in
C:\Program Files\InstallShield Installation Information (Please set "Show hidden
files and folders." in folder option in OS)
3) Please del the folder " Ulead VideoStudio 9.0" folder in C:\program
files\ulead system
4) Run Regedit from Start/Run in Windows task bar
5) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in
KEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
(If you always see Ulead VideoStudio 9 file name showed in the Add/Remove
Program, please do point 5)
6) Then reinstall UVS 9 again
