Send to mail recipient disabled
pwalgren
Post by pwalgren »
I have P explorer 8.5. The send to mail receipient button is disabled - greyed out - whatever. I have MS Office 2003 and Outlook is my default mail program. I have used P Expl 7 and used Outlook express and all was well. I reinstalled P Ex 8.5 and even reinstalled P Ex 7 send to mail etc was disabled in both. :cry:
Any Suggestions ???????
phdenis63
Reply to :Send to mail recipient disabled
Post by phdenis63 »
Below is the solution that a friend receive from the support service for the same problem but for Eudora. (The send to mail receipient button was disabled - greyed out). Since I have activated the MAPI server for eudora as described below, the button is now enabled. I hope that it will work also for you with outlook 2003.
Ph.Denis
Photo Explorer supports Microsoft Outlook, Microsoft Outlook Express, Netscape Messenger, Qualcomm Eudora, and any e-mail client with a MAPI server.
First, check if you have assigned any mail-client as default
For Outlook Express4.0:
1.Click Tools: Options.
2.Select General page in the Options dialog box.
3.Select Make Outlook Express my default e-mail program.
4.Select Make Outlook Express my Simple MAPI client.
5.Close Outlook Express.
For outlook Express 5.0 / 6.0
1.Open your Outlook Express
2.Select Tools: Options.
2.Select the General tab in the Options dialog box.
3.Under 'Default Messaging Programs' if you see 'This application is NOT the default Mail handler', then click 'Make Default'.
4.Click Apply then click OK.
For Netscape Messenger
1.Select Edit: Preferences.
2.Select Mail & Newsgroups in the Category list.
3.Select Use Netscape Messenger from MAPI-based applications.
4.Click OK
For Eudora
*** Eudora.
3.Select MAPI from the Category list.
4.Check Always under Use Eudora MAPI server.
Then, open Internet Explorer. Go to Tools > Internet options select programs tab and choose the one which you would like to be default mail-client here.
mathiaslink
Email grayed
Post by mathiaslink »
I have this problem also but this solution did not work for me. Apparently it is a common issue however.
