MISSING TOOLBARS
AfterDarkDesign
MISSING TOOLBARS
Post by AfterDarkDesign »
Photo Impact 11 was working fine. Today I boot it up no tool bars. I can get the galleries ect with F keys but can't get my tools bar or my file bar at the top to come back HELP!
heinz-oz
Post by heinz-oz »
Did you install the PI 11 patch? You can get it here http://www.ulead.com/tech/pi/pi_ftp.htm
AfterDarkDesign
MISSING TOOLBARS
Yes I have installed the patch. The only thing I cannot seem to retrieve back is the normal comand bar. It is just gone.
heinz-oz wrote:Did you install the PI 11 patch? You can get it here http://www.ulead.com/tech/pi/pi_ftp.htm
keenart
Post by keenart »
On the Command Menu item named My WorkSpace, select Customize…
On the Customize Dialog box, select the Tab named Toolbars. Under the Attributes named Toolbars: Make sure all of the Toolbars listed have a check mark in each box, otherwise they will not display.
If this does not work, try switching to another WorkSpace, such as Advanced and then back to the WorkSpace you normally use.
If neither work then your Ulead Installation is damaged.
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
Try also to delete the file:
C:\Documents and Settings\<username>\Application Data\Ulead Systems\Ulead PhotoImpact\10.0\profiles\current.xum
I hope i got the path right, if not just search for 'current.xum' in your profile.
X.
AfterDarkDesign
Command Menu
Thats the problem I don't have a Command Menu. That is the menu I cannot seem to retrieve.
keenart wrote:On the Command Menu item named My WorkSpace, select Customize…
keenart
Post by keenart »
There are no shortcut keys that restore Command Menu, and no Factory Restore Menus feature.
Palettes float and dock using the F6 key in Preferences that toggle on and off the Palettes, but not the Main Menus. Unfortunately, there is no way to restore the Command Menu. If you also delete the xum and cfg files Ulead will not restore them unless you reinstall the software.
My suggestion would be to uninstall Ulead, delete all of the Ulead folders remaining in both locations and reinstall.
Ulead rewrote PI11 From the ground up and so has to do a little clean-up work, and that will take a little time. I would suggest you write Tech Support, explain your situation.
AfterDarkDesign
Reinstalled Software
That is what I chose to do is reinstalled and voila the command menu reappeared. Go Figure.
keenart wrote:There are no shortcut keys that restore Command Menu, and no Factory Restore Menus feature.
Xyzzy2
ram: 8 GB
Post by Xyzzy2 »
keenart wrote: Ulead rewrote PI11 From the ground up and so has to do a little clean-up work, and that will take a little time. I would suggest you write Tech Support, explain your situation.
WOW, are you sure about this? I mean creating PI11 from scratch.
X.
Acchy
Post by Acchy »
Xyzzy2 wrote:Try also to delete the file:
X.
I had the same problem, with the missing menu bar. ( all of them to start with )
I found the above folder, and deleted everything in it. Reopened PI and it worked - it was back again.
So a BIG thank you to Xyzzy2 !!!
