JensMahlmann wrote:Right Heinz, I'll turn autosave off and see ...
One thing though, don't forget to do a manual save every time you did something to your image. I save under alternate names so I can get back to a previous stage if I don't like the latest alterations I did. I need to do that because I have PI preferences set to 5 Undo levels only.
It can put a strain on your system if you have too many undo levels because the program needs to keep track of changes you made. I think, in your case, that might be an area you should look at also. Because you add large images to an even larger image, there is a lot of stuff kept in the undo history, putting a strain on your RAM space.
I have also learned to turn off PI after I added a few large images to my collages. PI will ask me, before closing, if I want the large amount of data stored on the clip board available to other programs or if I want to clear it. My sytem runs a lot smoother since I do that. I'm sure there is a way in WIN XP to clear the clip board also but I use this way because it also clears the PI temp files.
Good luck
