How to change clip properties regarding aspect ratio
shasta
Hi, I have a problem with the aspect ratio of a movie I have captured on a digital videocam and have imported into ULead VideoStudio ver.9. When I capture the movie and import it into the program the aspect ratio is correct, that is a 4:3 ratio. I can see the image as a thumbnail in the correct format. However, when I drag a clip to the timeline the aspect ratio changes into a 16:9 ratio, even if the thumbnail I see in the timeline is of the correct ratio. Can you please tell me how to resolve this problem?
Hi Shasta, welcome to the forums..
To change the Project Properties, go to File/Project Properties or Alt + Enter, then click on the second Tab, (General). Look down at the bottom of this tab, it will have Display Aspect Ratio:. It should read 4:3 . If not, (16:9), then click on the drop down arrow to the right, and select 4:3.
This is only available when your project properties are MPEG. It is better to edit DV-AVI. There are numerous posts here that advise against editing MPEG.
Hi Videoman
Are you saying you cannot select 16:9 for project properties when using Dv-Avi.
I work with widescreen 16:9 for all my projects. I capture to Dv-Avi 16:9 and have no problems setting 16:9 for all my properties.
Shasta
Are you sure your video clip is not 16:9.
Right click a clip in the library and select properties.
Do the ‘attributes’ indicate 16:9 or 4:3.
Trevor
Shasta
Trevor
Hi Ron
I see what you mean, I am having trouble finding 16:9 for Avi capture.
If you capture to DV rather than Avi, that is from a digital camcorder you have no problems and no settings to bother about, other than the Dv-Type. I always use Type 1.
I am not surprised that we get confused with Dv and Avi.
Trevor
Trevor
