Output is 16:9 squeezed into 4:3
devo_111111
Post by devo_111111 »
So I have 5 clips from a Sony Z1U captured using the uLead utility by firewire.
Ok! So the menu has to be 4:3. But when I create a menu and then check during finish... the clips that play when using the buttons are 16:9 squeezed into the 4:3 frame.
When I don't create a menu just place clips in the workspace and then go to finish. The clips play in full widescreen.
I want my clips to play in full widescreen. What does making a menu do my clips?
Ian
You're looking in the wrong place!
On the EDIT tab right click the clip(s) and select "Output Display Options"
A dialog box appears where you can specify that this clip should be 4.3 or 16.9
In addition to this there are options for "On a Widescreen TV" Display is
As is
Source is letterboxed
Stretch
Keep Aspect Ratio
Keep Aspect Ratio (No pillarbox)
