CREATE VIDEO DISC
SURGE
CREATE VIDEO DISC
I TRANSFERRED FROM A 8 MM CAMERA IN MPG 2. TO MY COMPUTER. WHEN I TRY TO OPEN THE FILE FROM MY VIDEOS. A SCREEN APPEARS BUT IT IS BLANK AND THE HOUR GLASS APPEARS. WHEN I TRY TO CLOSE IT SAYS ULEAD IS NOT RESPONDING. I TRANSFERED THE TAPE THROUGH THE CAP WIZ. HOPE SOMEONE CAN HELP THANKS RICK
There is probably something wrong with your captured file. Will it play in Windows Media Player?
Analog capture is the trickiest part of this whole tricky digital-video business. You need a fast computer, and you can't multi-task during capture. If the computer can't keep-up, you'll get dropped-frames or some other form of corruption. What is your CPU speed? How much RAM do you have?
Ulead seems to be picky about video files. Sometimes a file will play OK but have some small "sneaky" corruption that will cause the Ulead programs to choke.
What capture hardware do you have? CapWiz is used with an MPEG-only capture device, right? MPEGs are trouble! You can use Movie Factory to make a DVD from a known-good MPEG file, but if you want to edit MPEGs, I recomend that you do NOT use Ulead for that. Get a special-purpose MPEG editor.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
