Running UVS in a Ram drive
drl711
Post by drl711 »
Has anyone tried running VideoStudio or any other Ulead apps in a ram drive? I hear rendering,etc is noticably faster (although not as safe (G).
I am thinking of creating a drive-loading UVS into it and running a test project.
drl711
I would be interested in reading the results of your experiments with this.
Steve J
gordon_fan_24
Post by gordon_fan_24 »
by RAM drive, do you mean a USB Flash drive? I'm not familiar with the term RAM drive.
drl711
Definitions of RAM drive
Post by drl711 »
Definitions of RAM drive on the Web:
* A disk drive that exists only in extended memory in your terminal or reader. You create, read, write, and delete files on a RAM drive the same way you can on a hard disk drive. RAM drives are faster than hard disk drives because the contents of a RAM drive are, by definition, always resident in RAM. The contents are destroyed when you cold boot the device.
http://www.intermec.com/eprise/main/Int ... lossary_QR
* A RAM disk, ramdisk or RAMdrive is a segment of active computer memory, RAM, which is being used as secondary storage, typically a role for a disk drive. Access times are greatly improved, because RAM disks are approximately a thousand times faster than hard disk drives. However, durability of data through power loss is completely absent, because they are made of normal volatile RAM. As a result, RAM disks lose their contents once the computer is turned off. ...
en.wikipedia.org/wiki/RAM_drive
gordon_fan_24
ohh, so its a drive that resides on the RAM, that acts like a hard drive, so that would make me wrong in calling it a flash drive. Wouldn't that take away from the usable RAM for the actual editing?
heinz-oz
Post by heinz-oz »
How much RAM do you have? :roll:
