Explorer 8.5 is very slow.
bjdky
How can I get Explorer 8.5 to load faster? It's too slow! Please help!
Bruce
Bruce
bjdky
Updated Profile
Now you have the info. Please give me some advice on how to speed things up.
Thanks,
Biff
Thanks,
Biff
- ram: 2 GB
- sound_card: Intel GMA 950
Thank you. There is no problem with your system specs.
I opened my copy it took about 5 seconds.
Just in case one of your pictures in the opening folder is causing a problem try:
file
Preferences
General
There is an option "Always start program in" try changing that location.
If this makes no difference it may be Windows related.
Try running the windows defragmenter
Then try running the Windows Chkdsk function.
Please advise of results.
Thank you
Steve J
file
Preferences
General
Thank you
Steve J
bjdky
bjdky
Still no luck
I uninstalled and reinstalled. I uninstalled nero picture and video software, thinking it was corrupted. Still no luck! I even cleared explorer from the registry. I'm at my wits end. I even tried to install in safe mode. Help!
Thanks,
Bruce
Thanks,
Bruce
htchien
If you installed many codec packs in your system, then it mgiht be the cause. Photo Explorer will try to enumerate all codec packs in your system before it loads.
If you do not need to view video files in Photo Explorer, just rename the VIO folder under the install path of Photo Explorer to some other folder name.
Also you can disable the Thumbnail Cache feature in File->Preference->Cache, this should also improve the startup performance.
In my system Ulead Photo Explorer starts up and ready in 25 sec (without renaming the VIO folder but cache feature is disabled).
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
