VS9 splits DV file :(
Xyzzy2
- motherboard: MSI Z77MA-G45
- processor: Intel i5-3570K
- ram: 8 GB
- Video Card: MSI R7770-2PMD1GD5 OC
- sound_card: Realtek 892
- Hard_Drive_Capacity: 6.25 TB
- Monitor/Display Make & Model: HP ZR24w
Hello!
VS9, patched.
It splits DV capture into 4GB chunks. VS8 worked OK on the same disk.
Split by scene unchecked.
Any ideas?
X.
VS9, patched.
Any ideas?
X.
- ram: 2 GB
- sound_card: Intel GMA 950
He is using Windows XP SP2 its in his profile.
It does sound like your using FAT32 instead of NTFS.
To convert view this article
http://www.microsoft.com/technet/prodte ... rtfat.mspx
Regards
Steve J
Regards
Steve J
Xyzzy2
- ram: 8 GB
My OS is under my System button (XP Home SP2).tyamada wrote:Usually you get 4Gig chunks if you are using Fat32 for you hard disk partition.
What Operating System are you using?
As I wrote, VS8 captures over-4GB files without probelms -> disk is NTFS.
X.
Here's the disk's properties:
Xyzzy2
- ram: 8 GB
ALL my drives are NTFS.tyamada wrote:Check your boot drive to see if is NTFS. The default setting for your working directory is on your boot drive under Document and Settings, your name.
Change your working directory in VS9 under File, Preferences, working directory.
The problem was also present before Windows reinstallation I performed a few weeks ago (to fix problems with PhotoImpact btw).
X.
heinz-oz
Xyzzy2
- ram: 8 GB
Which setting exactly is this? "Split by scene" in options panel is unchecked.heinz-oz wrote:Did you check your preferences to make sure you do not have "Split" activated for 4 GB?
BTW, I can use MS Movie Maker as back-up solution. Does any of you have experience with capturing with it (knowing MS, I am afraid it may do something "strange" to DV stream)?
X.
- ram: 2 GB
Xyzzy2
My apologies, I had to get my camcorder out to check this one.
I have been capturing with Media Studio Pro since I upgraded and didn't realise the following:
isn't present in VideoStudio.
I thought the capture modules were the same. Just goes to show that sometimes you upgrade and only notice a difference when you revert to the earlier product and then find something isn't there!
Steve J
Steve J
Hey, X.
Had the same problems and yes, had to explain to folks here that I did indeed know the difference between FAT32 and NTFS etc, etc etc. Here's the reply I got from ULEAD Tech Support (yes! they really do exist!). I think it cleared up the problem for me. Good luck:
Recv'd from ULEAD July 2005
Please logon as Administrator and try this reinstallation procedure;
1) Clean up C:\Windows\temp directory. Clean up all files in C:\Documents and Settings\[UserName]\Local Settings\Temp folder.
Uninstall VideoStudio 9 from control panel Add/Remove programs. Delete following folders =>C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead VideoStudio =>C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc =>C:\Documents and Settings\[Username]\My Documents\Ulead VideoStudio =>C:\Program Files\Common Files\Ulead Systems\
Proceed to step 2, even if you can't complete step 1.
2) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in C:\Program Files\InstallShield Installation Information (Please set "Show hidden files and folders." in folder option in OS)
3) Please del the folder " Ulead VideoStudio 9.0" folder in C:\program files\ulead system
4) Run Regedit from Start/Run in Windows task bar
5) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in KEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ (If you always see Ulead VideoStudio 9 file name showed in the Add/Remove Program, please do point 5)
6) Then reinstall UVS 9 again
Best regards, -Nelson Duay, Ulead Support Team
Help me! The paraniods are after me!
phishman
nice programming....
It's always a good sign when the only way to get a program to work is to completely reinstall it...
