Choppy/Blurry/Pixilated DVD from miniDV (videostudio 9?)
NattyPounder
Post by NattyPounder »
I just got a Samsung SC-D353 miniDV camcorder and began using it to create home movies. I just started creating DVD's on my computer. I am using Ulead Videostudio 9 to do editing and use a HP dvd200e burner to burn the disk. I am also using expensive blank DVD+R disks.
The problem arises after I put the burned DVD into my home dvd player. The DVD shows up slightly pixilated (sometimes choppy... just not as clear as it should be) and there is sometimes a short delay in the audio. The menu appers very clear however. I know it's not the camcorder because when I plug it in directly into the TV with the audio/video cables it is very clear. Is it Videostudio 9, or rather, a setting I need to change?
If someone could please help me I'd greatly appreciate it. Thanks!
Post by BrianCee »
First thing we always ask when someone has a problem like yours ,
Did you work exactly in accordance with the recommended procedure given in the first post in this thread :-
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=27
heinz-oz
Post by heinz-oz »
We could possibly tell you also which settings need changing, if only we knew what your settings were :roll:
