"Enlarge" Storybook view freezes computer
raygo
Post by raygo »
hi, posted this before;
When I am in storybook mode,[Ulead 9] I click the small "enlarge' icon on left side in order to see more rows of clips and everything freezes.. I have to "end program" This is the only technical problem I have with Ulead 9
Is this a glitch on my end or Ulead 9?
My install of 9 is boxed disk.
PeterMilliken
Post by PeterMilliken »
I doubt that anybody knows the answer to this (which is probably why you didn't get an answer before :-)) - I imagine (could be wrong :-)) that almost no users on this forum uses storybook mode, we all use timeline mode, so you will be unlikely to get an answer one way of the other. I just tried creating a small project in storybook mode and tried the enlarge icon - it worked OK for me, but that doesn't really prove anything since I only used about 6 clips to get to that stage.
Perhaps if you think about the following questions you might be able to answer the question yourself:
1. does it only happen with one particular project?
2. does it only happen after I have X clips in the project?
3. does it only happen if I have a particular clip in the project? i.e. just throw together a quick project with some randomly selected clips and see if the problem still occurs if it does then try another completely different random selection.
Otherwise all I can suggest is that you think about changing your workflow to doing your editing using timeline mode - it is really the more powerful and useful view since you have access to the overlay track, the audio track etc etc.
Peter
raygo
storybook view
Post by raygo »
yes, I agree..
I started out using storybook but am using the timeline view most of the time now... I think I discovered this glitch when I added about 15 - 5-10 second clips to a project at the end and then wanted to move them more to the front of the project. Since I was moving them 1 clip at a time and they are so small in timeline, thought it would be easier to see them all in storybook mode..
btw:
I did add a few random clips to a new project just to see if it would freeze up when I clicked Expand and it did.... Just one of those glitches that are not all that important... thanks for the help......
Post by Trevor Andrew »
Another way to move clips is to use the library.
Drag the clips that you want to move to the library, this will create a thumbnail copy. then delete them from the timeline. You can use Shift + Click to select multiple adjacent clips.
Now simply drag the clips back from the library to the front of your project.
Trevor
raygo
Post by raygo »
Thanks Trevor,
Always learn a trick or 2 here..
