straight to dvd quality
thebigman
Is the quality from straight to dvd as good as other methods ie to hard drive first or is it poorer
heinz-oz
Maybe...
In general, you are safer going to hard disk (in AVI/DV format) first.
MPEG encoding is CPU intensive. (Stand-alone DVD recorders have hardware MPEG encoders.)
I assume you're talking about analog capture. If the CPU can't keep-up with the real-time streaming video, or if it get's interrupted, you'll get a glitch or a dropped frame. It's not that the the CPU isn't fast enough on-average. But, Windows is a Multitasking operating system, and it's doing stuff in the background even if you are running only one program.
IMHO - Real-time analog capture is tricky enough without real-time MPEG encoding or real-time burning. If you do the MPEG encodeing later, the CPU can take it's time, and even if it's interrupted you won't get any problems.
And, you can't use 2-pass encoding in real-time.
I'm not saying that you shouldn't try it... It may work fine for you and your set-up. Just don't be surprised if there are "issues".
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
