I have several mpeg2 and DV video clips that I would like to combine to make a 25 min DVD home movie. Is it possible to combine these two types of file formats in the timeline and then create a video file of them all?
After that I would burn them to DVD.
All of the video clips have come from a High quality Sony hanycam DCR-HC90 DV camcorder.
My Mpeg2 settings are:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 16:9
Audio data rate: 224 kbps
My DV direct settings are:
Microsoft AVI files
24 Bits, 720 x 480, 16:9, 29.97 fps
Lower Field First
DV Video Encoder -- type 1
DV Audio -- Dolby digital??, 16 Bit
Will I have any quality issues are is this just a good / bad thing to do?
burning multiple video formats for DVD
Give it a try! It should work.
However, I have had lots of problems editing MPEGs. So if you get A/V sync problems or if Video Studio crashes, or anything else weird, convert the MPEGs to AVI/DV before editing. (Load the MPEG into the timeline and click share. Save the file as DV.)
In any case, your MPEGs are probably going to get re-coded, which is going to cause some quality loss.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Changing the thrust of the DVDDoug's comments a little, if all your clips came from the same camera, then for future reference, you should always capture from a mini DV camera using DV format, do your edits, and only then convert them to DVD-compliant mpeg-2s and after that, burn them to disc.
And if you still have the original DV cassettes, and do in fact run into problems rendering your current project, I would advise you re-capture those parts which you apparently captured direct to mpeg-2. This, to my mind at least, is a better option to converting the mpeg-2 back to DV (which will entail a loss of quality) and then re-rendering those new DV files back to mpeg-2 again in the end product, which will cause even further loss of quality.
As DVDDoug has said, you shoud be able to combine your DV and mpeg-2 files into one -- that is the theory. But experience also tends to suggest that trying to join multiple files with different video AND (apparently) even different audio formats used, may cause problems.
