MP3 files will not play in VS9
skiman123321
Post by skiman123321 »
I had a ton of problems with quicktracks and smart sound, but thanks to these forums, my problem was solved by going here:
http://www.smartsound.com/support/answe ... php?id=499
Thank goodness I did not format my hard drive as tech support wanted me to do!!!
Smart sound now works but I cannot play mp3's in VS9. I insert them to the audio track and when I try to play them, there is no sound.
If I convert mp3's to wav files and insert the wav file into the audio track, it plays. I am tired of work arounds and would like to find a way to fix this problem. Any help is appreciated. Thanks.
Post by Black Lab »
It has been discussed on the board many times that certain MP3s (or probably the codecs used) can cause problems in VideoStudio. A common solution is to convert the offending MP3 to a WAV file.
You can try notifying Ulead support, but they probably already know of the problem. Fixing it is a whole other issue.
Not that it's any consolation, but converting an MP3 to a WAV is one of the easier workarounds :roll:
Show me a perfect video editor for $100 and I'm there :!:
