In the preferences section of Ulead 8, the last tab has a question that reads:
"Limit Hard Disk Usage To:"
There is a box next to it that can be checked or unchecked. Mine has always been unchecked. Should I check it?
Then following this question it says:
1 MB (Max Space 44,835MB)
Do have this set properly?
A 'Preferences" setting question for Ulead 8
jchunter_2
rwindeyer
It puzzles me a bit why that is even there. The only reason I can think of: eventually you may want to burn a DVD; for a 4.7 Gb disc you will need around 9.5 Gb working room on the hard drive. If you fill all the space with clips you may be unable to burn - you do have the option to remind the computer to leave some spare space.
I, also, never use the thing.
jolobg
