You should read the FAQs on the Happauge site for Windows MCE.
http://www.hauppauge.com/pages/faq/support_faq_mce.html
This fact is how to use the other input to use a VCR.
http://www.hauppauge.com/pages/faq/supp ... mce.html#8
The trial version of MF4 doesn't support the Happauge capture plugin, it only installs to the Retail or ESD version.
Hauppauge PVR-500, UL MF 3.5, Video Composite Input - Help?
Sterling Babcock
I got the WinTV2000 working with capture!
Details:
Go to http://www.shspvr.com/smf/index.php?board=51.0
Go to Beta Lite CD Release 2.0.35.23258 is ready for download
Install Hauppauge WinTV2000 4.7.23045
Install WinTV-PVR 150/500 Release 2.0.35.23258
That seems to work, and I was able to capture MPEG2 video, so solution found.
I also plan to try: DVD MF3.5 -> MF 3.0 Hauppauge drivers -> MF3.0 Updates
to see if that will work. Currently the first two steps causes errors. I have not tried the third.
Thank you for all your help.
Details:
Here is a note that I received from Ulead Tech support on re-installing Movie Factory 3.
If in fact your version is 3.5 then you don't have to install the update 300P01.
Install the updates in the following order:
Update 300P01
DL Support Pack (2 parts)
Hauppauge Capture Plugin
Hope you can get it to work.
Update 300P01
