Transition Effects.
ppreston
Transition Effects.
Post by ppreston »
Does anybody know if you can have different transition effects for each image when creating a slideshow? It seems that you can only select one type of transition for the whole slideshow. :?:
niki516
Re: Transition Effects.
Post by niki516 »
ppreston wrote:Does anybody know if you can have different transition effects for each image when creating a slideshow? It seems that you can only select one type of transition for the whole slideshow. :?:
Are you using DVD Workshop 2? If yes, after you add the images, don't forget to select on it and check "Add transition effect" then select "Random" in the combox.
Hope this helps you. Good luck!!
ppreston
Post by ppreston »
Thanks, but obviously you didn't understand my question properly. I know you can add transition effects but can you add different effects between each picture on a slide show of your own choice?
ppreston
Post by ppreston »
Yes i am using DVD Workshop - that's why i posted it here??
GeorgeW
Don't be too hard...
Post by GeorgeW »
ppreston wrote:Yes i am using DVD Workshop - that's why i posted it here??
just a thought -- there are other versions of DVD Workshop. And in the other versions there could be different ways to accomplish the same thing. So I think the question was whether you are using the DVD WS 2.x version (and not some other version)...
George
niki516
Post by niki516 »
ppreston wrote:Thanks, but obviously you didn't understand my question properly. I know you can add transition effects but can you add different effects between each picture on a slide show of your own choice?
I asked "are you using DVD Workshop 2?" since I've never used DVD Workshop 1.x version. In DVD Workshop 2, you may see "Random" option in the combo box of the transition effect. This is the only way to add different transition effects between the pictures. If you want to assign the different ones, I am afriad the answer is NO.
Hope this helps.
Good luck!!
