A good Graphics Card for VS9
Lymers
Post by Lymers »
Has anyone any thoughts on a good AGP graphics card for use with VS9. Can't spend a fortune, will 256mB be noticeable over 128 ??
Cheers
Andy
GuyL
motherboard: ASUS P6T
processor: I7 920
ram: 6GB
Video Card: ATI 5870
sound_card: Auzentech X-fi Forte 7.1
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: LG W2753V & HP w2408h
Post by GuyL »
In my opinion, the graphics card has nothing to do with video editing.
If you are asking about a combination of video/capture cards then let us know. Also, if you are using TV Out with color profiles to try and judge what it will look like on a TV signal that is different too. As far as performance, it makes no difference. Spend the money on a hard drive or CPU.
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Lymers
Post by Lymers »
Thanks for the help. With regards to hard drives would you reccommend the faster SATA drives for access speed ??
GuyL
processor: I7 920
ram: 6GB
Post by GuyL »
Lymers wrote:Thanks for the help. With regards to hard drives would you reccommend the faster SATA drives for access speed ??
Yes, I would over IDE. Make sure you check what your motherboard can support first. If it can support SATA-II then go for that. If not, then make sure you get a regular SATA drive or a SATA-II with a jumper that allows it to work in the first generation mode.
If you can, dedicate the drive to video.
Guy Lapierre
