Eileanbeag wrote:I am very new to video and just wondered what you were talking about when you said to use the rubber band to delete sound
I'll try and give you an introduction to it...
Select one of your clips in the Timeline. Make sure 'Fade-in' is selected in the Video panel. Click on Audio View in the Timeline and you will see the black 'rubber band' line. It starts at the bottom (no volume) and shortly rises to join the red line (normal volume).
Hover the mouse over the small white square marker until it changes to a hand. Then drag to the left or right to reduce or increase the length of the fade-in.
You can create more markers by clicking on the rubber band when the cursor changes to a black arrow. Move them up or down to increase or decrease the volume at that point.
To remove a marker just drag it down off the bottom of the Timeline.
If I need to do anything complex here it can get a bit too fiddly. I prefer to split the audio and use an audio editor to process it.
Hope this helps.
John
