I created an IMAGE as an overlay. Then added a fade-out to it.
Worked fine. Later changed my mind and decided to remove the
fade-out. When I clicked on the object the fade-out selector
button was NOT showing as selected, but the object still fades
out. I can't seem to get the fade-out to dissappear. Even tried
switching it to fade-IN, and then remove that but that didn't
work either.
I think the object itself may be hosed... OR.... there is something
else to perform and I don't know how to do it.
Hmmmmm...
eatc7402
Eliminating fade-in/fade-out confusion
This is strange
, I tried to duplicate it, however can not. Every time I go back to the image to change it the Fade is selected, and I can deselect it.
Do you have a copy of the image in the library? If so drag and drop it beside, either before of after the "hosed" image. Then remove the one you're having problems with.
There is no other means to remove the fade attributes, that I can find.
Regards
This is strange
Regards
