Should i be splitting the movie? its a 30min movie.... reason i'm asking this question is because when i apply a filter to the movie (it filters the whole movie).... Should i split the movie every 2 min and apply filters to all of these sections? sorry for the silly question....
Filters
antzpompeii
Filters
After you capture a movie in AVI/DV format and then you edit....
Calver
I use a small free program called WinDV to capture AVI files from my camera. It creates a separate AVI file for each clip from the DV tape. I can then select the clips I want and add them to the timeline. Then I can do the final trimming of the clips, insert transitions, and add filters to individual clips where necessary.
John
John
The clip in the timeline is only a thumbnail representing your video file saved on your hard drive, usually in the working folder.
Applying a filter will effect the whole thumbnail.
Some Options.
1 / You can capture to Dv-Avi and select the ‘Split Scene’ option. This will split the captured file into pieces usually every time the cam corder recorded footage.
The individual thumbnails being placed in the timeline.
2 / You can ‘split by scene’ after capture. This will keep the main capture file in one, only splitting the thumbnails.
3 / You can use the scissors to cut the clips in the timeline anywhere you like.
Use this to edit and remove unwanted frames.
Once you have individual thumbnails you can apply the filters to any you choose.
You can use more than one filter to each clip (max 5 I think)
Hope this Helps
Trevor
Some Options.
Hope this Helps
Trevor
antzpompeii
Thanks JohnCalver wrote:I use a small free program called WinDV to capture AVI files from my camera. It creates a separate AVI file for each clip from the DV tape. I can then select the clips I want and add them to the timeline. Then I can do the final trimming of the clips, insert transitions, and add filters to individual clips where necessary.
John
Actually i also have Picture Package which is a very simple program,,,, i might also give that a go if i can't get around VS.
Thanks.
Antz
antzpompeii
Calver
Calver
- ram: 2 GB
- sound_card: Intel GMA 950
There is another way. It all depends upon the movie and why you need to include a filter in the first place.
Sometimes it is better to split the movie up, but not always.
Last year I converted all my Super 8 films to DVD
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8849
Some of these required that the whole video had adjustments to brightness/contrast etc. Some needed cropping to remove jagged edges, but those jagged edges seemed to slightly move about here and there.
To apply these filters without cutting the video, you can use KEYPOINTS.
As luck would have it I only answered a query about keypoints a few moments ago. View this post for an explanation.
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=11472
harperv
i use picture package to get my clips off my camera. then it is a simple matter of dragging and dropping them into the library. i can check them there to see if i want to keep or delete. then i bring them into the timeline and do any trimming etc.
i was using another program which then allowed me to join them together but that wasnt really necessary as i can do that in the add chapter menu.
My problem at the moment is that my husband only got the camera at christmas and i only have a couple of movies to mess about with at the moment. I burn them to a dvd rw and then go back and try more effects etc on the same old stuff.
I am so pleased you are asking all the questions its really helping me too.
