Going from Trial to Full version
willydeluxe
Post by willydeluxe »
After freeloading for 30 days I've just done the deed and paid up!
I need to know if I should install the full version over the Trial, uninstall first, or whatever.
And what, from where, should I save if I uninstall the trial? (My projects are saved already: is there anything else I should look for?)
Oh, and how can I clean up all the thumbnails from the library in one go? Where ARE they?
Very definitely uninstall the trial version first. And I imagine the files represented by the thumbnails will be in your working folder which, unless you changed it, will be in My Documents\Ulead VideoStudio\9.0.
Post by BrianCee »
As Ken has said the files represented by the thumbnails will be in your specified capture folder - but if you only want to clear the thumbnails from the library and not delete the actual files then just click on the first thumbnail to select it - go to the last one and hold down 'shift' while you select that - all thumbnails should now be selected - hit the delete key on your keyboard - click 'OK' at the prompt - goodbye thumbnails.
Control+select also works if the thumbnails you want to delete are not consecutive.
From what we have both said I hope you realise that the thumbnails are not your actual files - they are just icons pointing to the files - the two things are seperate and you can delete thumbnails and not files - you can do the other way round if you like (delete files not thumbnails) but then it becomes very messy next time you select a thumbnail !!
willydeluxe
Thanks.
