Delay between video and audio with a MPEG2 file
mtcova2001
Post by mtcova2001 »
:cry:
I used VS9 to edit an MPEG2 file captured from a french TNT channel. I did several cuts and I get a delay between audio & video on the edited MPEG2 file using the PAL MPEG2 option
Any idea ?
Technical informations
VS9 version 9.00.0114 SE DVD
Edited video details:
- video rate: 6Mbps 25 fps , 720x576
- audio rate: 224Kbps 48000Hz 2 channels
A threshold question: you don't say where in the world you live or captured this French program. Where was that? I ask because IIRC France uses the SECAM TV system. I realise this is not too different to PAL B, but if the broadcast was in SECAM and you were not using the French version of the program to capture, there could be a slight mismatch... Dunno ... just a thought. Otherwise, there have been quite a few posts on out of sync problems, including in the past couple of days. You could do a search for those.
