Does this link work for anyone else? I can an invalid address.irhyper2 wrote:SUCCESS!!!!
I went to SmartSound;s WEB site and solved itthrough the forum. Anyone haveing this problem to to this linkhttp://www.smartsound.com/support/answers/print.php?id=499
I followed the directions and it now works fine. Thanks to all of you. Especially you Steve for t aking so much of your time to try and help a Nimrod like me.
Smartsound problem
GuyL
- motherboard: ASUS P6T
- processor: I7 920
- ram: 6GB
- Video Card: ATI 5870
- sound_card: Auzentech X-fi Forte 7.1
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: LG W2753V & HP w2408h
Now using Adobe Premiere and Photoshop
Guy Lapierre
www.forefrontbusinesssolutions.com
Guy Lapierre
- ram: 2 GB
- sound_card: Intel GMA 950
Glad you got it fixed. In the coming weeks I intend to create a "Frequently Asked questions" which I shall place in the Tutorials Section.
I shall include this fix for anyone else who has this problem in the future.
Thank you
Steve J
Thank you
Steve J
tryirhyper2 wrote:SUCCESS!!!!
http://www.smartsound.com/support/answe ... php?id=499
Or the non print version http://www.smartsound.com/support/answe ... php?id=499trevor andrew wrote:tryirhyper2 wrote:SUCCESS!!!!
Video Studio X-3
LG BH10LS30
LG GH22NS50
LG BH10LS30
LG GH22NS50
irhyper2
Does thislink work for anyone else? I can an invalid address.[/quote]
Guy L. Here is the link again
http://www.smartsound.com/support/answe ... t&catid=14
I just checked it, and it wroks. The post that solved my problem is the very first post. I was getting eror messages the same as this person. Hope this helps. When you try and uninstall quicktracks through "add/remove, are you unable to do so. Quicktracks was there for me, but showed 0 size, and I got error messges when trying to delete
GuyL
- processor: I7 920
- ram: 6GB
Marlene
Marlene
Marlene
Marlene
yes as a matter of fact I did see it and went through the whole operation.
When I initially finished with the suggestions there I had all the music files including "Full Spectrum" under "all" and nothing in "owned". I checked the initial SmartSound file that I had saved and noted that one file was missing from the new download. I copied it over to the new download files and that is when the "Full Spectrum" files went to "owned" but there is no sound. I presume that file that I copied over should come out of the new download file but I am then back to everything being in "all" and nothing in "owned" then.
Marlene
Marlene
Marlene
Well I'm back today trying to sort this VS program out.
As I previously said after running the stuff that Brian mentioned above I decided today to run the link that Steve posted in about the second post on this thread backing up the files before doing so.
Would someone be so kind as to check your libraries file and tell me if you have what I have.
Well, I certainly have those three, but, from the point of view of a VS install, I also have Full Spectrum 22K.sdx, Full Spectrum 44K.SDI and Full Spectrum 44K.ICO, plus one labelled Full Spectrum.SDX -- though I suspect this latter relates to another editing program which also uses SmartSound and installs Full Spectrum as the sample library. (I also have a variety of SmartSound discs which I have installed and which have their own SDX and ICO files in this library.)
Marlene
Sooo it would seem that I am missing some important file extensions. I wonder what happened to them and if I can find them someplace without going through the whole operation again? I'll do a search on my hard drive.Ken Berry wrote:Well, I certainly have those three, but, from the point of view of a VS install, I also have Full Spectrum 22K.sdx, Full Spectrum 44K.SDI and Full Spectrum 44K.ICO, plus one labelled Full Spectrum.SDX -- though I suspect this latter relates to another editing program which also uses SmartSound and installs Full Spectrum as the sample library. (I also have a variety of SmartSound discs which I have installed and which have their own SDX and ICO files in this library.)
The SmartSound disks that you have are those additional music files you bought from Ulead?
Marlene
- ram: 2 GB
Your Smartsound library files are here:
C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc\Sound Files
The Libraries are here:
C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc\Libraries
Sorry I cant post any screen shots because the would be meaningless to you as I have several extra smartsound libraries installed.
