problem with firewire and camcoder
michele
Post by michele »
Hello i'd like transfer the video from my camcoder samsung vpd 15i to my computer by firewall 1394 but i not see the video on computer i can can move forward rewind stoP and play but i can't see my video and no sound so i can't record it. Is it a problem of service pack 2 window xp?
there are the pach or the new driver?Or is a problem of compatiby betwen program?
I already try with studio 8, powerdirector 5 and videostudio 9 but there is the same problem.
Help me!!!!
thank you
michele
continue...
Post by michele »
The problem show is "Movie Factory failed to connect to driver samsung msvd error 13011.3.3"
I already try the camcoder on a notebook and work fine with the same cable and windows sp2....
thanks
Hi Michele,
You've made 24 posts and you haven't complete your system information in your profile... :? Please complete it.
This almost appears to be a problem with your graphics card, since you can control your camcorder with the programs, but are having the same issues with several programs.
You can go to Start-->All Programs-->Accessories-->System Tools-->System Information. Then run a DirectX Diagnostics check.
Also check to see if you have the latest WHQL certified drivers, and/or the latest drivers for your graphics card..
Regards
michele
MY COMPUTER
Post by michele »
Hello, the caratheristic of my computer are:
Model Targa® Visionary 2600+ Multimedia PC
Processor AMD Athlon™ XP2600+ (333 MHz FSB) mit super Silent-Cooler
Software Microsoft® Windows® XP Home Edition, Star Office 6.0, Pinnacle Studio 8.3 SE, Pinnacle Hollywood FX, Pinnacle T-Rex, Panda Titanium Anti-Virus, Cyerblink Power DVD
Motherboard A7N8X (Targa Edition) mit der neuesten Chipset-Technologie (NVidia nForce2)
5 x PCI, 1 x AGP, 3 x DIMM erweiterbar bis 3 GB DDR-RAM, 2 x EIDE
RAM 256 MB DDR-RAM PC2700 (333 MHz) erweiterbar bis 3 GB DDR-RAM
Hard disc 120 GB Western Digital® UDMA-100 mit 7200 Umdrehungen
CD-ROM/DVD TOSHIBA DVD-ROM
16-fach DVD-lesen, 48-fach CD-ROM-lesen
Toshiba DVD-Brenner und CD-Brenner
Lesen: 12x DVD, 40x CD
Schreiben: 2x DVD-R, 1x DVD-RW, 16x CD-R, 10x CD-RW
Inklusive Brenn-Software VOB Instant CD/DVD
Floppy 3,5", 1,44 MB
Graphics ATI® Radeon®9500 Atlantis High Speed Edition
- 128 MB DDR-RAM
- DirectX9
- AGP 8x
- 256-bit Speicher Interface
TV / Radio Karte
Inklusive Software Power VCRII
Sofortprogrammierung der Aufnahmefunktion, Time Shifting, multifunktionaler Videotext fü
Soundboard Asus 6 Channel Dolby 5.1 Digital Sound mit digital und analog Aus- und Eingängen
Keyboard Kablelloses Multimedia Keyboard (Funkübertragung)
Mouse Kablellose Scroll-Mouse
Dimensions (WxHxD) mm 185 x 500 x 440
Power supply 300 Watt Fortron Source - PFC
Slot 5x PCI (2 davon frei)/1x AGP (8x)
Interfaces 6in1 Multimedia-Speicherkarten-Leser, 2 x USB 2.0, FireWire,
S-Video IN, Composite IN, Mikro, Audio IN, Audio OUT
Rückseite:
2 x PS/2, 1 x Parallel, 1 x Seriell, Center und Subwoofer, Rear Speaker, Front-Speaker, LAN RJ 45, 2 x USB 2.0, Line-in, Line-out, 1 x Mikrofon, FireWire 4Pin Anschluss, FireWire 6Pin Anschluss, Audio-Digital IN (SPDIF), Audio-Digital OUT (SPDIF), VGA (analoger Monitor), DVI-I (digitaler Monitor), S-Video OUT inklusive Adapter für Composite OUT, TV-Antennen-/Kabel-Anschluss,
Radio-Antennen-/Kabel-Anschluss, RJ 11 für Modem
Warranty 24 Monate inkl. Vor-Ort-Service, Hotline
Chipset Nvidia® nForce2
Communication 6-in-1 Targa® Speicherkarten Lesegerät
(Liest und schreibt Daten von CompactFlash, Sony Memory Stick, SD Card, Smart Media, IBM Microdrive und Multi-MediaCard (von Digitalkamera, MP3-Player etc.)
56K V.90 analog Modem, 10/100 MBit Ethernet (DSL Ready)
Michele,
Thank you for providing the information. Have you been able to capture using your firewire before this problem occured? If so, that would indicate something like your firewire cable maybe bad. Can you borrow another one to see if you have the same problems? It could also be the firewire port.
Have you had any other problems with viewing graphics or video on your computer? Any recent crashes, hangups? Did you run the DirectX diagnostics, and did it show any problems?
When you plug in or turn on your camcorder does windows recognize it? When you click Go to My Computer is the Camcorder listed, like a Drive?
Then one last thing, try unplugging your firewire from both the computer and your camera. Make sure the camera is turned off before unplugging or plugging in anything. It can cause damage to the camera. Then shutdown your computer, unplug it from the power source for about 30 seconds. Then plug the computer in, and turn it on. When it is fully booted, plug the firewire cable back in. Do you hear the new device tone? Does windows acknowledge you just plugged it in?
Then turn on the camcorder, and start DVD Moviefactory to see if things have changed...
michele
Post by michele »
Hello, thank for the fast reply, i not are at home now, so the only information that i can say are:
I have try the camcoder and the wire on another computer using MF4 and it all ok
Two years ago the camcoder and the same wire was ok, so i think that there is a possibility of conflit between program or can be a codec lost?
I not have other problem with graphic or video on my computer,i can capture very well by analog input or usb2.0
The window recognize camcoder samsung in the "risorse del computer" but if i double click on the icon it say that there is a error or the device could be used by another application.
An another things..what do uoy mean for "unplugging your firewire from both the computer and your camera" i am italian an don't know english very well....
thanks...
My appologies, you know more english then I Italian, :oops:
Unplug= disconnect...:)
maddrummer3301
Post by maddrummer3301 »
Using ServicePack 2 there have been problems reported with the Firewire interfaces. (Not on all systems).
I would goto the Microsoft web site troubleshooting guide.
Always plug the camcorder into the computer with the camcorder OFF.
Then turn the camcorder ON. Never hotplug a firewire cable the same method as a usb cable.
Never plug the camcorders firewire AND USB cable in at the sametime.
This can cause damage to the camcorders interface circuitry.
To see if windows is recognizing the camcorder after it's plugged in and on open up "My Computer". You should see it there, double-clicking on it will bring up screens to preview the contents if windows is working properly.
Or, under "Control Panel" use the "Scanners & Cameras" icon to access the device. If windows doesn't load the device then no video program will be able to access the device.
Nice PC Specs.
Hope this helps,
MD
michele
Post by michele »
Hello, thanks at all...
I had tried an external hard disk with firewire of my computer and it work fine so i think that this device ( iee1394) function....
The camcoder and the cable that i have tried on the other pc work fine and the OS was window xp home edition with SP2 , the same of my computer...
thanks...
michele
Post by michele »
Hello, when i click to My Computer the Camcorder is listed like a Drive "samsung dv camcoder" then i double click on and today it function i can see the video on window prewiew it a miracle, i had do nothing and it function ??? boh, but the problem with moviefactory is on, it say me failed to connect to driver Samsung - MSDV 13011:3:3....
thank at all
That's good that your system is now seeing your camcorder :)
Now to get Movie Factory to see it, which it is recognizing the camcorder is present, just had trouble connecting to it.
Try this if you haven't...
1. Turn off your camcorder.
2. Close MF.
3. Turn on your camcorder, place it in Playback.
4. Windows should have prompted you, asking what you want to do, Capture/Edit with... and provided a list of programs to choose from. DVD MF should be one of them.
5. Select DVD MF.
6. Once DVD MF is open, are you now able to capture?
I only have DVDMF4 so I don't know the layout/workflow that MF3 would have. In MF4, I click on the camera Icon to capture. It then shows my camcorder is present, (Sony..and then the capture driver, which is Direct Show)..
Are we getting closer to success?
michele
Post by michele »
Thanks for the fast reply, i try it this evening..
maddrummer3301
In MovieFactory you probably need to change a setting.
But, Under "My Computer" your camcorder shouldn't be displayed as
a "Drive Letter". That is an interface setting within the camcorders setup menu. It should simply show up as a device.
You may have an option in the camcorders's setup menu that references the IEEE1394 or iLink port and it's Mode of operation.
Mode's may be "Streaming" or XXX_Compatible. I would check that. Windows may be thinking you have a "Camera" connected and not a camcorder, they are different. Just like flash drives or memory sticks.
Within the windows window you should be able to hit the play button on the camcorder and see the video playing in the window.
Check you cam's setup menu settings the and go to MF and click on the capture Icon.
First to start goto the MF's Capturing Module.
Clcik on the "DownArrow" to display addtional parameters.
Click on "Advanced Settings" Icon -> then
Click on "Device Control" and then click on the box "Current Device", I think for firewire it's the "MS 1394 Device Control" selection but many times it can also be the "TI 1394 Device Control".
Then in that same screen click on the "Options" icon and you should see your camcorder listed as the "Active Device".
Note: If you have more than one camcorder connected this is the screen you can assign the other camcorder or device.
You may also have to change the "Capture Plugin".
The 2 standard modes are for direct Mpeg2 capturing or DV capturing.
Click on "Advanced Settings" Icon -> then "Change Capture Plugin".
The "Ulead DSW MPG Capture Plugin" is for direct coversion to mpeg2 video format (not recommended unless you have a fast computer, which you DO!).
The "Ulead DirectShow Capture Plugin" is for standard DV capturing and is the standard capturing for most video camcorders.
After you select the "Ulead DirectShow Capture Plugin" then go back to the Device Settings screen and verify the correct driver and make sure your video camera is recoginized.
Note: If there are any special drivers or equipment that MF4 can use to capture with they will showup under the "Change Capture Plugin".
I have a small usb camera that showsup in that screen although I don't use it for capturing.
Hope this helps,
MD
michele
Post by michele »
Hello, i tried turn on the camcoder the windows recognize and open a window that say "open this device with one of this program:
-Pinnacle studio
-Noone operation
windows not ask me to open with MF4
If i open MF4 it say "Movie Factory failed to connect to driver samsung msvd error 13011.3.3"
If i open with Pinnacle not function
I had try with videostudio 9 i can pilote the camcoder but the screen on the windows prewiew is black and no sound and with driver direct show there is an error "failed to build a prewiew graph error 15001:33:1 15023:4:2"
Thanks at all
michele
Post by michele »
Eureka!!!! yauuuuuu!!!
Now function i have found the problem....
Only write on Start -- Execute--- this words :
regsvr32 %windir%\system32\qdv.dll
And now it function!!!!!!
I don't know the why but it function and i am very happy!!!
Bye and thanks at all
