DVD Movie factory 3 SE Error code 5003
mikey53179
Post by mikey53179 »
can anyone tell me how to fix this error code I get when I'm in the last stage of m0vie factory 3se it's called the out put stage. after waiting 35 min I get the error code 5003 and a file number it cant write to :x . I have tried to relaod the program 3 times and still get the same message.I have since installed muevee studio 4 and it works great. but I like the edit features that this movie factory 3se has. it will burn the movies that mf3 wont.I just have to see if it I can edit in mf3 and burn it in maevee studio 4. :roll:
mikey53179
new error?
I have since played with some setting and now I have a 5003 error massage. but still no luck I cant get it to burn dvd after editing it. if I do a direct burn it works great. :?
mikey53179
5003 error
Still NO up date :evil: Flaws= ERRORs
VJ1138
Post by VJ1138 »
I have the smae problem. No one has responded to my post, and this is the only place on the web that seems to know how to solve any problems relating to MovieFactory 3 SE. It's frustrating. When the program doesn't crash, it tells me there's a an error with the source file (5003), then that it can't open, and then repeats itself once more. I've gotten the error before, and it just went away when I restarted the program or re-did the project, but it's not working this time.
mikey53179
junk
There is a up date you can try. but when i installed it my computer system.my system did a hard crash. i had to unplug my system 3 times just to get it working enought to remove DVD movie factory 3 se and up grade.since i remove the program my system works great and it should its only a couple of months old and i have never had a problem with it until i in stalled dvd movie factory3 se.So not having dvd mf 3se on my system.i decided just for the fun of it..i installed dvd movie factory 4. the file was 94 megs and guess what my computer did the same. it locked up. :shock: I uninstalled it and i'm trying Nero.So far iNero and other programs that i'm try on a trial are working great..my version of dvd movie factory 3se was puchased with hardware.
VJ1138
Post by VJ1138 »
The only update I found is a two parter, and it says that it cant' find Movie Factory 3 installed on my system.
mikey53179
here is the link
http://www.ulead.com.tw/ulead/member/me ... member.cfm?
its not two parts its to site that you can download from.i hope this helps you...it didnt work for me.also i had to turn off my firewall to downlaod this.
