Tutorial: PhotoImpact: Creating DVD Menu from scratch
For PhotoImpact, Paint Shop Pro, PhotoExplorer, PhotoExpress, GIF Animator & WebUtilities
Glennmizu
Post by Glennmizu »
Hello Steve, I wonder if you can help again.
My menu looks great and works but 1 problem. On the main menu in my DVD player when I select which clip I want the selection is not being highlighted.
I can press next 2 times and then press enter or play and it will play the correct clip but it can be confusing as the clip is not highlighted when selected.
Any ideas?
Glen,
Have you installed the DVD Menu Plug in
http://www.steve-jones.pwp.blueyonder.c ... lug_in.zip
If so I strongly suggest it is a powerful addition to the Menu Creation tools you have at hand.
After installing the plug in it is found under the effects Menu
Although there is only the option to create a DVD Menu for DVD Workshop 2, it will work with MF4 / VS9 / PS4 just the same.
You can now assign object names by selecting them in the object list (Top right)
Then in Object Class select what an object is plus the color mapping settings.
In the sample below you will also see that I have chosen to include a background video.
The final tab “Preview and export” will confirm that all objects have been correctly named. You can also click the objects on a preview screen to ensure they highlight as required.
You will also find a user guide in PDF format at
C:\Program Files\Ulead Systems\Ulead PhotoImpact 11\plugin\MDT\MDT2.pdf
After installing the plug in from my zip file.
Regards
Steve J
Glennmizu
Post by Glennmizu »
Thanks Steve that was a great help, but unfortunately I couldn't use it on this project as I am working on a 16:9 wide.
I finally copied a pre-made menu from MF4 in 16:9 and then made changes to it by adding Japanese writing and and saving it as an object with the background layer.
I am happy to report that it now works well and the menu items are highlighted when chosen by the remote controller.
Thanks again for your help.
Best regards
Glenn Waters
www.glennwaters.com
The Official DVD Menu plug in for PhotoImpact 11 has now been released
http://www.ulead.com/pi/plugin.htm
For those who have already installed the plug in from my zip file, they appear identical.
Steve J
Using Movie Factory 4 Menus with Version 5
maddrummer3301 wrote:Hi,
You can add directories and name them separately making them custom.
If you want to add all the MF4 templates is easy.
Make sure MF3/4 and 5 are Not running.
Location of the MF4 templates:
C:\Program Files\Ulead Systems\Ulead DVD MovieFactory 4.0 Disc Creator\Ulead DVD MovieFactory 4.0\Template -->(Sub-directories of templates).
First off the program separates the 2 different aspect ratios in direct relation to whatever you have the aspect ratio Icon set at (bottom of the menu creation screen).
So on the bottom of the screen make sure the aspect ratio is set to the correct sub-directory in MF5.
The following location is to copy the 4x3 menu templates.
Location to copy the "Complete Directories" to:
C:\Program Files\Ulead Systems\Ulead DVD MovieFactory 5\Ulead DVD MovieFactory 5\Content\Menu Template\4x3 --> (subdirectories you want to ADD/Copy from MF3/4).
Copy the complete directories Under the 4x3 directories (this makes them subdirectories) IF your templates are 4x3. When you start MF5 it will load them in.
After you have them loaded in click on the "Aspect Ratio" icon on the bottom of the screen and change it to 16:9. You will see the MF4 templates disappear because MF5 is now using the 16x9 sub-directory which you haven't copied anything into yet.
Hope this helps,
MD
Further to the excellent post by MD
move all the 16.9 Menus to
C:\Program Files\Ulead Systems\Ulead DVD MovieFactory 5\Ulead DVD MovieFactory 5\Content\Menu Template\16x9
In Version 4 the 4.3 and the 16.9 are sort of mixed in with each other but easy to identify and seperate.
Now you get 16.9 menus from version 4 in version 5 as well.
Steve J
sleekdigital
What about VS 10
Post by sleekdigital »
Doe this work for VS 10? If not is there some way to ge to the assets that are used in the menus so i can maybe duplicate an existing menu and then swap out assets... or some other wat to make my own menus?
Please view:
http://forum.corel.com/EN/viewtopic.php?t=13854
In addition
PhotoImpact created Menus will work in VS10 and also MF5
I have just installed PhotoImpact 12.
I can confirm that the DVD Menu Plug in
Here will work with version 12.
The zip file is set up to extract the files to the following location
You need to modify this so that the files are extracted to
C:\Program Files\Ulead Systems\Ulead PhotoImpact 12\plugin\MDT
briggs555
Post by briggs555 »
I tried doing what you said and it didnt work.
is there something im missing , its fairly straight forward on how to do it
and Im no noob to computers.. So I must be missing something somewhere.
Was really Looking forward to making my own Dvd menus.
any help?.
The DVD Menu Plug In after installation of the above will be found under the
effects menu.
2log wrote:There is a beta DVD Menu Plug-in for PhotoImpact 12:
http://www.explorecommerce.com/members/ ... 1&ID=10109
Wow
Just downloaded it and it accepts 16x9 as well as 4x3
but best of all it enables you to create your own Smart Scene Menus.
I think I will be having some fun with this one
ShortStack
Post by ShortStack »
it wont let me put any "objects" in my "menu" it says i need to download something.......... what would i need to download?
I think you need to be more specific regarding your error message.
ShortStack
any time i try and put a an object or text or anythingelse it basicly says i dont have it in my computer it says i need to download it or it wants me to browse for it.
